i have the code p1161
118,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
CARLOS ROMERO
My car is not accelerating.
Mar 8, 2016 at 2:58 AM
  • 31,937 POSTS
Check for this fault.
Short circuit in throttle body wiring circuit due to:
Engine coolant entry to control unit connector 32 way gray. (32V GR)
Pull the plug off the throttle body and check for corrosion on the pins.
Coolant originated from leaking coolant temperature sensor.
Mar 14, 2016 at 7:18 PM
