Oil pouring out of the engine
200,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
LELEMARIE
I don't know where to start. Use to go through quart of oil every couple weeks now literally I go through a quart just by driving it fifty or more miles. I mean once parked there is a huge puddle of oil under the truck. Where do I start at? What causes oil to leak that much from a vehicle?
Feb 2, 2019 at 6:11 AM
SCGRANTURISMO
  • 4,897 POSTS
Hi Lele, my name is Alex and I will be helping you.
Well, the reason you have oil leaking from your engine is probably a gasket failure, and it sounds like a good one. Not to worry though, this should be easy and straight forward to fix. Here is a helpful link that should explain what to do. Let us know if there is anything else regarding this or another problem that we can help you with.
Thanks, Alex.
https://www.2carpros.com/articles/engine-is-leaking-oil
Feb 2, 2019 at 9:21 AM
CJ MEDEVAC
  • 11,000 POSTS
The "normal" leaky places might be the valve cover, maybe the oil pan gasket, harmonic balancer seal. These are slow leakers (but could get worse.) We're talking gravity leaks or slung out of an opening.
As far as "sudden and heavy loss" parts, one might look at the oil pressure sending unit. These items are generally metal and screw into the engine. The "kicker" is the center portion of the sender is plastic. The unit is under constant oil pressure. So when the plastic portion separates/cracks loose on the sender, you have a 30-70 PSI stream (just a wild guess) of oil constantly leaking out. It doesn't take long to expend a bunch of oil.
This is a guide from our "Repair Guides" (top right of our pages) It might aid with some of your leaks.
Not saying this is the issue, but something to check out, below are a picture of the oil sender, the other being it's location.
The Medic
Feb 2, 2019 at 9:50 AM
LELEMARIE
Thank you so much for your response and the diagram as it will be very helpful.
Feb 3, 2019 at 5:05 AM
  • 55,649 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Feb 6, 2019 at 5:49 AM
