checked headlight bulbs ok. change fuses still nothing. checked relay switches nothing.
Mar 21, 2015 at 3:08 AM
HMAC300
✓Experienced Mechanic
there is a connector for headlights under battery tray and may be corroded. also for wiper the ground is there so pull battery and tray out and check for corrosion at connector and ground. that may be your problem. if not have it scanned for codes as it may be a body module or drl module for headlights.
