your mode actuator may be the problem try pulling HVAC fuse inside car for sixty seconds with key on. then reinstall it may reset it otherwise check to see if it gets power or not. it may be bad.
Image (Click to enlarge)
Jul 17, 2016 at 1:34 AM
MAXIMILIAM
MEMBER
There is nether fuse there with HVAC on it.
John Lavers
Jul 17, 2016 at 7:26 PM
MAXIMILIAM
MEMBER
What size would the fuse be?
John Lavers
MAXIMILIAM
MEMBER
And I have a problem with window motor on the right side theirs power going to it all the it wont go down.
John Lavers
Jul 17, 2016 at 7:27 PM
✓Experienced Mechanic
The actuator shown in the earlier response is known for failing, you can unplug it and check for power at the plug when defrost is commanded.
