Vent Door Problem
2005 FORD ESCAPE
103,000 MILES • V6 • AWD • AUTOMATIC
SUNNEY
i have minimal or no floor heat in the front seats, also one of the passenger vents barely blows any heat through
Feb 9, 2014 at 8:39 PM
  • 110,244 POSTS
You have to check vent door operation. The doors are what changes direction.
Feb 9, 2014 at 8:58 PM
SUNNEY
How do I check the vent door on the floor?
Feb 10, 2014 at 2:16 AM
  • 110,244 POSTS
The vent doors are in the duct work under the dash. When you change the direction of air flow, check to see if they are working.
Feb 10, 2014 at 8:47 PM
SUNNEY
Do I have to remove anything under the dash to get to these doors?
Feb 10, 2014 at 9:44 PM
  • 110,244 POSTS
When I get home tonight, I will check my manuals to see exactly what needs to be removed. However, you should be able to hear them move.
Feb 11, 2014 at 12:08 AM
BLAKEF
Stopped blowing air through the vents. It happened after I turned off the the center vent /AC/defroster selector switch. Air still blows out of the defroster vents and the AC works as well as the hot cold temperature control switches. The speed control on the blower fan works. I have replaced the center switch with a new one but still have the same problem. What changes the directional vents on the car vacuum or electricity. Could this be a bad relay ( they all seem to be in good shape) I have also checked all the fuses and they are good
Nov 11, 2019 at 10:33 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Hi
Vacuum controls the modes your in default mode now. So have lost vacuum. Hear any hissss undre dash? if not check engine compartment see if a small hose is off that goes from intake to the bulkhead into pass compt.
Let me know
Thanks for donate
DLD11649
BLAKEF
MEMBER2003 FORD ESCAPE
Air Conditioning problem
2003 Ford Escape 6 cyl Four Wheel Drive Automatic
My 2003 Escape stopped blowing air through the vents. It happened after I turned off the the center vent /AC/defroster selector switch. Air still blows out of the defroster vents and the AC works as well as the hot cold temperature control switches. The speed control on the blower fan works. I have replced the center switch with a new one but still have the same problem. What changes the directional vents on the car vacumn or elctricity. Could this be a bad relay ( they all seem to be in good shape) I have also checked all the fuses and they are good
DLD11649
Member
2003 Ford Escape
I have a 2003 Escape with the same exact problem as described above.
I have not replaced the center vacuum control switch as the previous person.
Here are the diagnostic steps I took.
1. disconnected the vacuum line that runs thru the firewall into the cabin. hooked a length of vacuum hose to that line. applied suction to the line with the switch in the "defrost" mode. It held vacuum.
2. Turned switch to each of the other settings and one by one tried to apply vacuum. None of them held vacuum. I tried this with the engine off and with the engine running.
Applying vacuum to the black vacuum line that runs to the switch and getting vacuum that holds would indicate that the line is not disconnected in the cabin or damaged. That line goes directly to the switch in the console. Where do the multicolored vacuum lines go from the switch? Do those lines go to separate vacuum motors? Or is there another manifold at the other end of the multicolored lines?
SCGRANTURISMO
  • 4,897 POSTS
Hi, my name is Alex and I will be helping you. Here are a couple of links that probably will be helpful. Let us know if you need any more help. Thanks, Alex.
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
and
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
LUCKYUNICORN
I had this problem and hed to fix the broken vacuum line the guide helped me.. I love this site.
