There is heat blowing from the midway vents but no heat to front defrost or lower feet vents?
BRENNERBRANDON
  • 2016 JEEP PATRIOT
  • 2.4L
  • 6 CYL
  • 180,000 MILES
When I turn the heat on in the vehicle and set it to the Midway vents it blows out warm air when I switch to defrost it instantly goes cold as well as when I switch to the lower vents.
Sunday, October 8th, 2023 AT 8:37 AM
  • 109,885 POSTS
That is an interesting one. When you switch to defrost or the floor, does the airflow direction change accordingly?
I ask because there is a mode door actuator that is responsible for airflow direction and a blend air door actuator that is responsible for air temperature. What you described ties them together, which is very odd.
Sunday, October 8th, 2023 AT 2:25 PM
