Check Engine Light on, how much would it cost to repair?
125,000 MILES • 4 CYL
ABDI17
  • 5 POSTS
Fuel pump power control module.
Fuel pump control module.
Fan 1 control circuit .
Powertrain control module.
Transmission control module.
O2 sensor.
PCM (MAF).
PCM.
Aug 31, 2022 at 10:26 PM
  • 110,251 POSTS
Did someone tell you everything you listed needs replaced? If that is the case, I have to say it is unlikely that all these things failed at the same time. By chance, do you know what the diagnostic trouble codes are that were retrieved?
Sep 1, 2022 at 12:42 PM
