Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
Le Baron
Interior
Instrument Cluster
Replace/Remove
I have a problem with my kilometer meter.
1993 CHRYSLER LE BARON
165,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
BARBOU
MEMBER
I have a problem with my kilometer meter. I changed the switches but nothing happens. How to check electric?
Mar 19, 2017 at 9:18 PM
HMAC300
Experienced Mechanic
scan for codes it may be a speed sensor going bad. it can also be the dash but scan first.
Mar 19, 2017 at 11:47 PM
BARBOU
MEMBER
thank you the code is: K04800879 . We changed the sensor but nothing, I also have more cruise control. There must be a fuse somewhere ?
Mar 20, 2017 at 2:49 AM
HMAC300
that code doesn't relate to anything that a scanner puts out it should be a p code or b code or U code
Mar 20, 2017 at 4:59 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
