codes p0302, p0305,p0171, p1000
1997 FORD EXPLORER
170,000 MILES • 4.0L • 6 CYL
DAN2002
  • 9 POSTS
Have a miss. Codes are p0302, p0305,p0171, p1000 in that order. Changed plugs and wires clean the mass air flow, no change.
Jul 25, 2016 at 9:20 AM
SATURNTECH9
  • 30,869 POSTS
So is the miss only at idle and while driving down the road you cannot feel it?
Jul 25, 2016 at 10:54 AM
DAN2002
  • 9 POSTS
both.
Jul 25, 2016 at 11:33 AM
SATURNTECH9
  • 30,869 POSTS
Is it a constant miss like those two cylinders are not firing? or does the miss come and go?
Jul 25, 2016 at 11:53 AM
DAN2002
  • 9 POSTS
the miss is mainly at idle, but you can feel it a like when driving.
Jul 26, 2016 at 7:02 AM
good afternoon,
the first thing I would do is verify fuel pressure. with the lean code. I would make sure the fuel pump is pumping the correct pressure. you can rent a tester at a parts store to check.
Jul 26, 2016 at 8:17 AM
DAN2002
  • 9 POSTS
Checked the fuel pressure and it is getting the correct amount of pressure. It is getting 40 psi running with switch on 29 psi.
Jul 26, 2016 at 10:46 AM
SATURNTECH9
  • 30,869 POSTS
I would be looking for a vacuum leak with the p0171. it is more then likely a vacuum leak.
Jul 26, 2016 at 1:18 PM
