Have a miss. Codes are p0302, p0305,p0171, p1000 in that order. Changed plugs and wires clean the mass air flow, no change.
Jul 25, 2016 at 9:20 AM
SATURNTECH9
✓Experienced Mechanic
So is the miss only at idle and while driving down the road you cannot feel it?
Jul 25, 2016 at 10:54 AM
DAN2002
MEMBER
both.
Jul 25, 2016 at 11:33 AM
SATURNTECH9
Is it a constant miss like those two cylinders are not firing? or does the miss come and go?
Jul 25, 2016 at 11:53 AM
DAN2002
MEMBER
the miss is mainly at idle, but you can feel it a like when driving.
Jul 26, 2016 at 7:02 AM
good afternoon,
the first thing I would do is verify fuel pressure. with the lean code. I would make sure the fuel pump is pumping the correct pressure. you can rent a tester at a parts store to check.
Jul 26, 2016 at 8:17 AM
DAN2002
MEMBER
Checked the fuel pressure and it is getting the correct amount of pressure. It is getting 40 psi running with switch on 29 psi.
Jul 26, 2016 at 10:46 AM
SATURNTECH9
I would be looking for a vacuum leak with the p0171. it is more then likely a vacuum leak.
Jul 26, 2016 at 1:18 PM
