car stalls at idle/stops.and won't restart
147,065 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
BEVERLY1
I have a intermittent stalling problem, car cuts off at idle/stops. It will only restart and stay running if you turn the heat off if you leave the heat on it will start and than cut right off. Weather does not make any difference.
Jan 21, 2014 at 2:59 AM
HMAC300
  • 48,601 POSTS
clean your battery cable ends and clean battery to body ground first.
Jan 21, 2014 at 11:39 PM
BEVERLY1
Battery is new and cables are clean and grounds good.
Jan 22, 2014 at 6:49 AM
HMAC300
  • 48,601 POSTS
Try cleaning the throttle plate on both sides and iac hole with choke cleaner otherwise have a local pro look at it.
Jan 22, 2014 at 7:50 AM
