I have a code saying that my auxillary battery is bad or not charging?
2003 MERCEDES BENZ E500
280,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
CHRIS1977IMPALA1
MEMBER
I tested the auxillary battery with a volt meter and it tested 12.8 volts and I tested the relay and it's good, so what could be the problem?
Mar 29, 2026 at 10:57 AM
CANNON1349
✓Experienced Mechanic
Hello, a multimeter is not a confident way of testing a battery. 12.8 volts tells us that the battery is charged, but not that it can handle the load of starting a vehicle. You can remove and take the battery to any parts store to have it tested, or of course drive the vehicle to those stores. As long as the battery is easily accessible for them they can test it in the vehicle.
William
Mar 29, 2026 at 12:25 PM
CHRIS1977IMPALA1
MEMBER
It's a brand new battery
Mar 29, 2026 at 12:41 PM
CHRIS1977IMPALA1
MEMBER
And I had them test it before I purchased it, I think it might be the connection between the relay and the ECU?
Mar 29, 2026 at 12:42 PM
CANNON1349
It's not uncommon for a new battery to fail a tes. If you can clear the code see how long it takes for it to return after clearing.
William
Mar 29, 2026 at 12:43 PM
