engine roars. I think it is the fan
140 MILES • V8 • 4WD • AUTOMATIC
ROBERTA CONAWAY
I have a hemi and when I stop at a stop sign the engine roars and even though I have the brake on it surges ahead.
Oct 27, 2015 at 12:58 PM
  • 110,246 POSTS
If the fan clutch is engaged and won't release, it will make noise. Actually, it has been described as a jet engine.
Take a look through this link. It explains how it works.
https://www.2carpros.com/articles/how-a-clutch-fan-works
Also, here is a link that explains common symptoms related to a bad fan clutch:
https://www.2carpros.com/articles/fan-clutch-symptoms
If you determine the fan clutch is bad, here is a link that shows in general how one is replaced. You can use this as a guide.
https://www.2carpros.com/articles/fan-clutch-removal
You will need special tools to remove the clutch, but most parts stores will lend you the tools. See pic 1 below for tools needed.
I hope this helps. Let me know if you have other questions.
See pic.
Jul 19, 2021 at 2:39 PM
