I have a humming sound when driving?
3.2L • V6 • TURBO • AWD • AUTOMATIC
RICHARD71
The faster you go the louder it gets. My wife took it down to have the oil changed and they said that the throttle body had a lot of carbon build up. I got some cleaner and cleaned the throttle body and that didn't get rid of the noise. I also checked the rear differential and the fluid was low. I changed the fluid and noise it still there. Anyone have any idea what is could be.
May 23, 2015 at 2:42 AM
WRENCHTECH
  • 20,760 POSTS
It could be a bad wheel bearing, irregular tire wear or differential bearings. Does it change when you go into a corner? I have seen bad bearing hubs cause this.
https://www.2carpros.com/articles/whirring-sound
May 23, 2015 at 4:08 AM
SAM.SMALL
Yep the front bearing were out in my car cost me $132.00 to get the bearing and fix it.
Dec 5, 2019 at 3:22 AM
