It’s saying shift malfunction E what does that mean?
Jul 28, 2024 at 11:12 AM
✓Experienced Mechanic
Can you please give me the code number? I need it to help fix it, but I have seen the shift solenoid E go out and need replacement, here is the location so you can swap it out if needed. Check out the images (below). Let us know how it goes.
Image (Click to enlarge)
Jul 29, 2024 at 3:24 AM
RICKEY68
MEMBER
The code is p1733. Saying shift malfunction E what does that mean ?????
Jul 29, 2024 at 5:38 AM
RICKEY68
MEMBER
The code is p1733. Saying shift malfunction E what does that mean?
Monday
Jul 29, 2024 at 2:11 PM
trouble code (DTC) P1733 typically indicates an issue related to the transmission, specifically with the third clutch pressure switch. So we were correct in replacing the shift solenoid E as in the image above.
