Intermittent cranking and no current to the fuse box
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
FPARRA196026
Sometimes it cranks and starts and sometimes it does not. I just replace the starter and the battery it was running up until a week ago then it started the same problem again. There no current going to the fuse box and there no crank. What could it be? is it something I can do myself rather than pay all sorts of money to a mechanic?
Aug 9, 2016 at 7:20 AM
  • 55,684 POSTS
When it does crank over I would use a test light at the starter solenoid trigger wire. Is sounds like you got a bad starter.
Here is a guide that can help you
Let me know what you find
Best, Ken
Aug 12, 2016 at 3:26 AM
  • 55,684 POSTS
FROM FPARRA196026
Hi Ken
Thank you for answering my email regarding my 2008 BMW 328i I just wanted
to let you know that year and model had a recall on the positive battery
cable and attachment to the fuse box I called corporate BMW office they set
everything to have my vehicle repaired at no cost thank you once again for
your help.
Dec 13, 2016 at 4:04 AM
  • 55,684 POSTS
No Problem!
Please let us know what you find out so it will help others.
Best, Ken
Dec 13, 2016 at 4:05 AM
