Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Accord
Suspension
Ball Joint
Replace/Remove
i had the left ball joint and axel snapped in the process the neutral saftey switched changed also
2004 HONDA ACCORD
120,000 MILES • 2.3L • V6 • 2WD • AUTOMATIC
LAYLOW135
MEMBER
1 POST
The car makes a funny noise when i try to put the car in reverse it no longer engages can that be due to the neutral safety switch.
Nov 6, 2015 at 3:54 AM
HMAC300
Experienced Mechanic
I kind of doubt it ti is the switch have a trans guy check it may be a torque converter or something inside trans.
Nov 6, 2015 at 11:02 PM
HMAC300
you may also have a bad axle so he can check that as well
Nov 6, 2015 at 11:03 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
