Display screen not turning on?
13,678 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
ANDRIN ATEM
  • 414 POSTS
Hi, please I have an issue with my Audi Display screen not turning on, can I please have a diagram for the network wires and voltage signals for Can H and Can L? It fault tells me no communication, which is the 2 wires. A diagram of the network bus will help me solve this issue. Thank you.
Audi Q7 3.0 Tfsi supercharged Quattro.
Sep 30, 2024 at 11:55 AM
  • 55,691 POSTS
Hi Andrin,
Here are the wiring diagrams for the BUS circuities and the display itself. I would check fuse # 12 and #10 in the fuse panel on the left side of the dash, and the fuse # 11 and #8 in the same fuse panel.
Here is a guide to help and the fuse locations as well:
Oct 1, 2024 at 7:43 AM
ANDRIN ATEM
  • 414 POSTS
Thanks Ken, you have been like super man. I appreciate and thank your team for doing such a great work.
Oct 1, 2024 at 8:04 AM
  • 55,691 POSTS
Our pleasure, let us know how it goes or if you need anymore help.
Oct 2, 2024 at 2:11 AM
ANDRIN ATEM
  • 414 POSTS
Thank you once more again for providing vital informations on the Suzuki I was working on. Finally solved the problem today of no acceleration, the was a short coming from the transmission module, on live data, both the throttle body and accelerator pedal open to 100% but after you start the car,the throttle body stay about 36%, so in disconnecting the transmission module, the engine responded normally.
Oct 9, 2024 at 4:05 AM
  • 55,691 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Oct 10, 2024 at 4:24 AM
ANDRIN ATEM
  • 414 POSTS
Sure, 2carpros is my sure bet. Thank you very much Ken for following up with me.
Oct 10, 2024 at 4:42 AM
