The car listed above is a c2 coupe. I thought my starter was bad, but I took it off and tested it to be good and the constant power to the starter is good. it's the wire that engages the starter when the key is turned on that does not get any power once the key is turned to start the car. So, I need help troubleshooting this problem. Please and thank you.
Sep 4, 2022 at 5:12 AM
