Hard to start and running issues
162,456 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
AUSTINGORDON12345
It is hard to start but when it starts it idles good. When I put it in gear and take off I have to take off easy if I do not and push the pedal down it bogs and tries to stall, but I let out on it and it is fine. Sometimes when it quits I can hook some jumpers up to it and jump it off and it will fire right up. I do not know what is wrong with it I need help please.
Oct 5, 2018 at 6:36 PM
  • 55,748 POSTS
This sounds like a classic fuel pump going bad slow to pressurize and maintain pressure. Here is a guide to help you confirm the issue and diagrams below to how you how to change the fuel pump:
and
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Cheers, Ken
Oct 7, 2018 at 5:48 AM
