Engine problems when it is cold outside
KPATERSON
  • 1996 PONTIAC BONNEVILLE
  • 0.5L
  • 6 CYL
  • 19,600 MILES
I don't know if the above is accurate - live in Michigan car quits when freezing and snowy weather. Does fine when mild weather
Car will quit after about 5 minutes on the road but only when it is freezing and snowing. Let it wait for 10 minutes or so it will start again, but quit a minute after moving. My genius mechanic had it when it was mild weather though and obviously could not reproduce the problem. He said to keep 1/2 of a tank of gas or more and that should do it, it has not. I am sure lots is rusted underneath as the gas and break lines seemed to be metal.
Sunday, January 4th, 2015 AT 12:30 PM
SATURNTECH9
  • 30,869 POSTS
Have you tried to see if the computer sets any codes when it wont start? Also have you seen if you have spark when it wont start? Or if it will start on carb spray when it wont start?
Sunday, January 4th, 2015 AT 1:13 PM
JDL
  • 16,098 POSTS
If it cranks good but won't start when the problem is ongoing, have a helper crank it while you visually check for spark at the plugs. If spark everywhere, use a gauge and check fuel pressure. You can do these tests. Yes, with intermittent issues, you have to test when problem is ongoing.
Sunday, January 4th, 2015 AT 1:16 PM
Related Engine Stall While Driving Content
