loses power when accelerating
130 MILES • 3.8L • 6 CYL • RWD • AUTOMATIC
MARCUS RIOJAS
What would cause my v6 engine to lose power when accelerating and shake like it wants to turn off? Note - That i already changed the spark plugs, spark plug wires, coil pack, and throttle body sensor
Jun 10, 2017 at 6:20 AM
HARRY P
  • 2,292 POSTS
Could be low fuel pressure. Either rent a fuel pressure tester and check it or have a mechanic check it. With the key on and engine off, you should get 25-40 psi. With the engine running, you should get 30-50 psi. If you are not getting enough pressure, it could just be clogged fuel filter, or you could need a fuel pump. Let us know.
Jun 10, 2017 at 7:41 AM
RENEE L
  • 1,260 POSTS
Hi MARCUS RIOJAS,
Here is a helpful link to an article from this site with step by step instructions and pictures explaining the process of checking the fuel-system-pressure-and-regulator.
If you need further assistance please come back to the site we are here to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Jun 10, 2017 at 7:44 AM
