I don't even know where to start
170,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
ERICOJ1
Engine died. Had a 0 mile atk engine put it. Right after the install it threw a code. The shop that replaced the engine thought it might be a computer issue and said I should take it to the dealership. The kia dealership said it was a crank shaft positiion sensor which they replaced. I took the car and 20 miles later the check engine light came on. I pulled into a brakes plus who said it was a knock sensor. It was cheap to do so I told them to go ahead. I then made the 70 mile trip from Denver to my house. The next day the car would not start. When it finally did it would not go over 15mph and stalled. I coasted into a local shop who said the catalytic converter was the issue. The issue is that when it is cold it will not start. Later in the day it will start fine and run OK but not great. I would guess it can't be a converter issue because it could not run fine one minute and stall the next. Now there is a code for a cylinder 4 mis-fire. I have never been so frustrated in my life.
Jun 26, 2014 at 4:38 AM
KHLOW2008
  • 41,812 POSTS
Is the cylinder 4 misfiring code present all the time?
When engine is able to start, does it run well without any problems?
When engine is unable to start, you need to check there and then what is missing, sparks or fuel related.
Jun 26, 2014 at 4:47 AM
