I changed my calibers, but the brake was burning. My rpm jump up and down seems that the catalytic converter is stopped up.
Jan 25, 2021 at 8:21 AM
✓Experienced Mechanic
Is the issue with the brakes burning or an engine-related issue? If you replaced the caliper and the brakes are stuck, I need you to try something. When it is stuck, open the bleeder on the brake caliper and see if it releases.
Do that and let me know what happens.
Jan 25, 2021 at 12:11 PM
LARRY SUMBRYEL
MEMBER
The wheel sensor is bad.
Jan 25, 2021 at 1:06 PM
LARRY SUMBRYEL
MEMBER
The brakes are no good.
Jan 25, 2021 at 1:07 PM
Do you know what caused the pads to stick and burn up? With new calipers, you shouldn't have an issue with the brakes. As far as a wheel speed sensor, here is a link that explains how to replace one. If you know which one is bad, let me know and I can give you more specific information.
