fluctuating RPMs, possible clogged catalytic converter
2004 CHEVROLET SUBURBAN
273 MILES • 5.3L • V8 • 4WD • AUTOMATIC
LARRY SUMBRYEL
MEMBER
FOLLOW
I changed my calibers, but the brake was burning. My rpm jump up and down seems that the catalytic converter is stopped up.
Jan 25, 2021 at 4:21 PM
CAR REPAIR CONTRIBUTOR
Is the issue with the brakes burning or an engine-related issue? If you replaced the caliper and the brakes are stuck, I need you to try something. When it is stuck, open the bleeder on the brake caliper and see if it releases.
Do that and let me know what happens.
Jan 25, 2021 at 8:11 PM
LARRY SUMBRYEL
MEMBER
The wheel sensor is bad.
Jan 25, 2021 at 9:06 PM
LARRY SUMBRYEL
MEMBER
The brakes are no good.
Jan 25, 2021 at 9:07 PM
Do you know what caused the pads to stick and burn up? With new calipers, you shouldn't have an issue with the brakes. As far as a wheel speed sensor, here is a link that explains how to replace one. If you know which one is bad, let me know and I can give you more specific information.
Let me know if this helps or what I can do to help.
Jan 26, 2021 at 2:59 PM
