Accidentally touched the positive battery post with my wrench starter does not engage
200,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
KEVIN1245
I accidentally touched the positive battery post with my wrench and got a spark. So after that happened I then removed the negative battery connect and proceeded to replace my power brake booster. After I was finished I replaced the negative battery post and went to test the booster, but could not get the van to start. I have all my instrument cluster lights, and the battery is new but the starter will not engage. I thought that maybe the starter relay was bad after the incident so I replaced it and still no starter. I then replaced the ASD relay still no starter. At this point I am lost.
Dec 5, 2018 at 1:00 AM
CARADIODOC
  • 34,417 POSTS
Relays are not going to be damaged by shorting the positive post to ground. (The ASD relay has nothing to do with cranking the engine). First listen next to the starter relay or feel it with your fingers to see if it clicks when a helper turns the ignition switch to "crank". If it does not, start with these tests. The cranking system can be broken down into four circuits, each with a corresponding test point at the starter relay. Find that relay, then unplug the connector so we can take the readings there. You can use a digital voltmeter, but for these tests, a test light is faster and can be more accurate. Before we get to testing, check the terminals to be sure they aren't corroded. When you probe a terminal, be careful to just touch it. If the probe is shoved into a terminal, that one can become spread and make intermittent contact later.
Put the test light's ground clip on the battery's negative post or any paint-free point on the body. Probe the black wire in the connector. You must find 12 volts there all the time. Next, probe the yellow/black wire. You must find 12 volts there when a helper turns the ignition switch to the "crank" position. If you find both of those voltages are missing, there is likely a fuse link wire that is burned open.
If those two voltages are okay, move the test light's ground clip to the battery's positive post, then we will check the two remaining circuits for a good ground. Probe the brown wire first. If the test light is bright, that verifies the starter solenoid wire is okay, and the solenoid itself is probably okay. We will follow up more on that later if necessary. Probe the brown/yellow wire. If the test light does not light up, the neutral safety switch is not turning on. You can try shifting between "neutral" and "park" multiple times, but regardless if that works or not, that switch is the suspect. Let me know what you find with these tests.
Dec 5, 2018 at 7:08 AM
KEVIN1245
So I had light at the blk wire all the time, and on the yel/brn during start position no light, the second test with the clamp on the pos post brn wire had light and so did the yel/brn, I then tested all fusable links before and after the link and had light in both places, I then tested the ignition coil primary and secondary ohms resistance
The primary was 2 k ohms, and the secondary was 7.54 k ohms, according to my Haynes manual the primary should be 1.35 to 1.55 k ohms, and the secondary should be 15 to 19 k ohms, so at this point I dont nowhere to go now from here or what else to test.
Dec 5, 2018 at 9:43 AM
CARADIODOC
  • 34,417 POSTS
What are you doing with the ignition coil? Lets stick to the starter system. I should have thought of this right away. Given that you were working under the dash, that is where you are going to find the cause of the problem, and the lack of 12 volts you found on the yellow/brown wire proves that. The fuse link wire has to be okay since you have 12 volts on the black wire.
The ignition switch is mounted low on the side of the steering column. First verify the connector is fully-seated so all the terminals are making contact. Next, since everything else works, there is a real good chance the switch is simply out-of-adjustment. That is set by loosening the two 5/16"-head screws, then sliding the switch up or down the column.
The only other possibility is two terminals in the connector are blackened from being overheated, but that is not likely to occur to the starter circuit since it is not on long enough to get them that hot. Still, look at the terminals corresponding to the yellow/brown wire, and the red feed wire. If those look like they were hot, and the plastic is melted around them, the switch will have to be replaced and those two terminals replaced individually. I will describe how to do that in the unlikely event it becomes necessary.
Dec 5, 2018 at 11:21 AM
KEVIN1245
So I found the issue, the system has a security chip and the card that goes into a slot and the contacts were corroded. So I cleaned them, now the starter engages but it will not start. It tries but it will not turn over.
Dec 5, 2018 at 12:22 PM
CARADIODOC
  • 34,417 POSTS
Please elaborate on "starter engages but it will not start. It tries but it will not turn over.". If you hear a rather loud single clunk from the starter solenoid each time you cycle the ignition switch to "crank", but the starter motor does not spin the engine, that is a common problem with the little silver Nippendenso starters, and it has an inexpensive fix. Before we get to that, measure the voltage on the large battery cable right on the stud on the starter. You must find 12 volts there all the time. Watch if it disappears when a helper tries to crank the engine. If it drops to 0 volts, there is a bad connection or the wire is corroded off the terminal on one of the battery cables.
If this is related to some card or chip, that is not factory. Chrysler did not have any anti-theft systems in 1989. Your starter circuit is very simple and reliable, so we should be able to figure out how to bypass whatever you have in there now that is preventing the starter from working.
Dec 6, 2018 at 9:00 AM
