I cannot find speed sensor
179,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
MIKE KEREZMAN
My uncle just put a new engine identical with old one in and couldn't figure where two connectors go. All gauges work but speedometer and odometer. I cannot seem to locate the speed sensor on the manual transmission.
Nov 19, 2019 at 12:49 PM
  • 110,248 POSTS
Here are the directions for VSS replacement on a manual. It will explain how one is replaced, but more importantly where it is located on the transmission. The attached pics correlate with the directions.
____________________________________________
2005 Chevrolet Cavalier L4-2.2L VIN F
Vehicle Speed Sensor (VSS) Replacement
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Vehicle Speed Sensor Service and Repair Procedures Getrag 5 Speed Manual Transmission Vehicle Speed Sensor (VSS) Replacement
VEHICLE SPEED SENSOR (VSS) REPLACEMENT
Removal Procedure
pic 1
1. Disconnect the vehicle speed sensor (VSS) electrical connector.
pic 2
2. Remove the retainer bolt.
3. Remove the retainer.
4. Remove the VSS.
5. Remove the O-ring.
Installation Procedure
1. Lubricate a new O-ring with DEXRON III transmission fluid.
2. Install the new O-ring.
pic 3
3. Install the VSS retainer. Install the vehicle speed sensor (VSS) assembly.
4. Notice: Refer to Fastener Notice in Service Precautions.
Install the VSS retainer bolt.
^ Tighten the bolt to 9 Nm (80 inch lbs.).
pic 4
5. Connect the VSS connector to the VSS.
6. Lower the vehicle.
Let me know if this helps.
Nov 19, 2019 at 1:15 PM
