I bent my driver side door backwards, how to fix without replacing the door?
200,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
JODY YOUNG
I bent my driver side door backwards. How to fix without replacing the door?
Jan 15, 2024 at 3:01 PM
  • 55,859 POSTS
That is difficult to fix without getting a new door. How bad is the damage? The door hinge mounts are bolted to the door frame so replacement can be rough without taking the door off. You will need to remove the front fender to remove the door. Once the door is off you may be able to hammer the hinges back into position. It does look like you can get new hinges though. Check out the images (below). Please upload pictures or videos of the problem so we can see what's going on.
Jan 16, 2024 at 2:42 AM
