when started rpm's are either really high or pulsating
100,000 MILES • AUTOMATIC
KAHREEM
When I start it up my rpm's are either really high or pulsating. it also runs hot maybe from the rpm's being so high? And when I put it in reverse or drive it takes a few seconds to takeoff. What could be the problem?
Sep 25, 2016 at 2:09 PM
WRENCHTECH
  • 20,758 POSTS
First eliminate all vacuum or air leaks in the system (very important)
You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carburetor cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
Sep 25, 2016 at 10:00 PM
