When replacing the CV axles, is there anything else that should be replaced at the same time?
2009 TOYOTA YARIS
190,099 MILES • 1.5L • AUTOMATIC
PHOENIX111
MEMBER
1 POST
I am told that both my CV axles are worn and will need to be replaced. Is there anything else that should be replaced at the same time?
Dec 14, 2023 at 2:29 PM
✓Experienced Mechanic
When the axles are purchased, most times they purchase a half shaft. This includes both CV joints and the axle.
As far as things that need to be replaced, only if there is evidence of wear or damage. For example, inspect the axle seals on the transmission. When you take things apart, make sure the hub bearings are good and the ball joints are tight.
Let me know if that helps. Also, let me know if you have other questions.
Dec 15, 2023 at 8:01 AM
