i am having problems with my car.
2008 DODGE AVENGER
105,000 MILES • 1.6L • 4 CYL • 4WD • AUTOMATIC
DEAUNDRA
hi i have been having problems with my car and i have a grinding noise in my brakes that sounds completly bad once i come to a complete stop. can you please let me know what it is?
May 10, 2015 at 11:52 AM
CARADIODOC
  • 34,381 POSTS
Most likely the brake linings are worn out and need to be replaced. A periodic brake system inspection will find this before it gets to grinding metal on metal. By now you can expect to also need new rotors, but fortunately they aren't as expensive as they were 20 years ago.
Have your mechanic check all four brakes. He will make a list of what is needed to return the system to safe operation.
May 10, 2015 at 12:01 PM
