I am begging you for your help
160,000 MILES
SMSPANG
Hi. I really need your help. I have a 1996 geo prizm 1.6L. The other day got stuck, was able to get a jump and made it home. When trying to start it up nothing, no click, no nothing. I had the alternator, battery, and starter looked at. Everything is fine. Also checked out all the fuses. I heard it could be the fusible link wire or maybe a bad connection. Please tell me if any of this sounds right. I am in a really bad spot financially, and could really use some expert advice.
I swear if u help me out i would glady come back and donate. I am saving whatever money i do have for repairs. but if u can save me the mechanics fee. I would rather give it to someone who out of pure kindness decided to try and help me.
Jul 2, 2013 at 9:17 AM
FREEMBA
  • 1,152 POSTS
Checkthe fusible links in the fuse box underhood near the battery. The fusible links are square(ish) and their tops are clear so that you can see the metal fuse inside. if this fuse is broken (burned in two), you need to replace it inorder for the engine to start. The fusible links are the "fuses" closes to the fender.
Jul 2, 2013 at 11:39 AM
