will crank and not stay active
218,375 MILES • 3.1L • V6 • 2WD • AUTOMATIC
AKRAPSON
I have this issue where the car wouldn't crank. So I replaced the negative ground wire that shorted out and it still wouldn't. Then replaced the starter.
Now it will crank and not stay active. I lose all power and the car cuts off as soon as you put into drive.
I may be a lady but I have come to the extent of my knowledge.
Please help. Thanks.
Dec 23, 2019 at 1:51 PM
  • 110,246 POSTS
I need to get a better understanding. Does the vehicle now start? Does it run normal before you place it in gear? By any chance, have you had the computer scanned to retrieve diagnostic trouble codes?
Take a look through this link and see if anything helps. Also, let me know specifically what is happening.
https://www.2carpros.com/articles/stall-at-idle
Dec 25, 2019 at 11:17 AM
