2005 Hyundai XG350 acceleration
58,550 MILES • 6 CYL • FWD • AUTOMATIC
SALTYPUP
After 4 years of running fine, all of a sudden my car has stopped accelerating when I am on the interstate. I'll be driving along and when I step on the pedal...nothing happens. I can floor it sveral times and still nothing. I'll then pull over (put brakes on) and when I am slowing down or stopped, the car will then run normal again.
I took it to the dealer, it happened to driver/tester and they decided that it was the fuel pump, they replaced it and the sock. When I was driving home, it happened two more times.
I am almost out of warranty and would like the dealer to fix my problem while I'm still under.
No one seems to have a clue? Do you?
Jun 5, 2010 at 3:47 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 5, 2010 at 11:16 AM
