2004 Hyundai XG350
2004 HYUNDAI XG350
FSMITH804
Engine Performance problem
2004 Hyundai XG350 6 cyl 87000 miles
I just recently replaced my fuel pump and fuel filter and now i cant seem to get my car started it's like theres no fuel getting to my engine i triple checked the pump and filter to make sure that it was installed correctly and its on there right. i just cant seem to figure this out. if you could get back to me as soon as possible i would appreciate it.
Nov 10, 2009 at 9:13 AM
RACEFAN966
  • 5,029 POSTS
Tell me what is it doing? Does it crank over and just not start? Have you checked to see if you have spark? Do you have fuel getting to the fuel rail? Let me know what you can and we will take it from there.
Nov 10, 2009 at 1:14 PM
FSMITH804
it does crank over,and there's no fuel getting to the rail.this morning i got my meter out and found out theres no power going to the fuel pump theres a wire that clips to the top of the panel where the fuel pump is connected and thats the wire that has no current.the fuel pump does not turn on i asked around and i was told to check the relay but i have no clue where its located
Nov 11, 2009 at 5:48 AM
RACEFAN966
  • 5,029 POSTS
This relay controls the fuel pump and it is located behind the center of the dash on the center support bracket. Make sure the gray wire has power.
Nov 12, 2009 at 1:48 AM
