2003 Hyundai XG350
86,651 MILES • 6 CYL • FWD • AUTOMATIC
PEGE
when driving usually for extended hr/hrs on interstate at
70 mph-then for no apparent reason cars stops accelerating and drops to 30-40 mph-no check engine light-started around 2005-got the first check engine light
Oct. 09-codes were PO171 and PO174. Have replaced mass air flow sensor, timing belt, sensor assy-thrott-used gas accord to manual then switched to highest rating.
Original owner, kept up reg maintenance
Nov 6, 2009 at 2:35 AM
MERLIN2021
  • 17,250 POSTS
These are mixture lean codes, so check the fuel pump pressure and check for vacuum leaks, stuck EGR.
Nov 6, 2009 at 7:25 AM
