2002 Hyundai XG350 Tune up
146,000 MILES • 6 CYL • FWD • AUTOMATIC
TP4906
Years ago a tune up was points, plugs, condenser and maybe plug wires or a distributor cap. What is involved with a tune up for a 2002 Hundai XG350.
Mar 14, 2009 at 12:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
With your mileage ( aprox. 150,000 ) recommended dealer tune up includes replacing the following:
Air cleaner/element
Automatic transaxle filter and fluid
Engine coolant
Drive belts
Engine oil and filter
Rotate Tires
INSPECT the following:
A/C refrigerant
Ball joints
Brake system (including hoses, lines, cables)
Drive belt tensioner and pulleys (inlcuding accessories i.e. alternator, power steering pump etc..)
Driveshaft boots
Exhaust system
Fuel filler cap and fuel system
Parking brake
Power steering system
Steering linkage and rack/rack boots
Suspension bolts
Timing belt
Vapor Hose
Of course if it has been awhile since you had any maintenace done then spark plugs, wires and coil packs may be desired to have replaced as well.
Thanks for using 2CarPros.com!
Mar 14, 2009 at 1:26 PM
