2002 Hyundai XG350 STUCK KEY
2002 HYUNDAI XG350
JIM_1907
Interior problem
2002 Hyundai XG350 Two Wheel Drive Automatic 36000 miles
KEY STUCK IN THE SWITCH....WILL NOT GO TO LOCK TO REMOVE KEY
Jan 25, 2009 at 2:06 PM
2CARPRO JACK
  • 11,533 POSTS
Has it give you problems in the past? If not, try turning the steering wheel from side to side to see if it is a problem with the steering lock. If not you may need to replace the tumbler assembly
Jan 25, 2009 at 11:20 PM
