2005 Hyundai Tuscon 13 Fault codes HELP!!!
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
TORRIEND
I just bought a 2005 Hyundai Tucson about a month ago, I just purchased the plates for goodness sakes. Soon after I bought it, it would begin to jerk and hesitate at stop signs. Then shortly after the check engine light came on. I won't lie, it took me about two weeks to get a diagnosic test on it and boy was it worth it. In total 13 different defaul code came up and now I'm so confused I don't know where to start. Now the car will jerk very hard when I am getting out of first gear and will often time die. I will list all the default codes below. Please tell me possible reasons for these and where I should start. Keep in mind that I am a female with no mechanical wit at all.
p0170
p0171
p0173
p0174
po300
p0301
p0302
p0303
p0304
p0305
p0306
Feb 9, 2009 at 7:52 AM
STEAMMISER
Below is a list and explanation of the codes you are having.
with no mechanical backgroung I would tell you to take to a shop/dealer and have the repairs done.
although you have numerous codes there may only be one or two things wrong, they just compound themselves and create more codes. In other words if you fix one problem and eliminate the code for it, that may cure some or all of the problems.
P0170 Fuel trim (FT), bank 1 – malfunction Intake leak, AIR system, fuel pressure/pump, injector(s), EVAP canister purge valve, HO2S
P0171 System too lean, bank 1 Intake/exhaust leak, AIR system, MAF/VAF sensor, fuel pressure/pump, injector(s), HO2S
P0173 Fuel trim (FT), bank 2 – malfunction Intake leak, AIR system, fuel pressure/pump, injector(s), EVAP canister purge valve, HO2S
P0174 System too lean, bank 2 Intake/exhaust leak, fuel pressure/pump, injector(s), AIR system, hose connection(s)
P0300 Random/multiple cylinder(s) – misfire detected Spark plug(s), HT lead(s), injector(s), ignition coil(s),low compression, wiring
P0301 Cylinder 1 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0302 Cylinder 2 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0303 Cylinder 3 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0304 Cylinder 4 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0305 Cylinder 5 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0306 Cylinder 6 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
Feb 25, 2009 at 1:35 PM
JORGE BERRIOS
Good evening TORRIEND,
Were you able to find a solution to this problem? I am experiencing the same issues myself.
Thank you in advance.
Mar 8, 2017 at 8:28 AM
  • 31,937 POSTS
It is a good idea to clear all codes and do a drive cycle, this will set current codes and you will not waste time chasing problems that aren't there, do this and report back codes that are set for further assistance.
Mar 8, 2017 at 4:02 PM
JORGE BERRIOS
These are the codes the ECU is reporting after clearing all codes and doing a drive cycle:
P0170, P0173, P0300, P0303, P0304, P0306
These are the parts I've replaced thus far:
- Spark Plugs
- Spark Plug Wires
- Ignition Coil
- Purge Valve
- Starter Motor
- MAF sensor
Car is Hyundai Tucson 2006, 2WD 2.7L V6
Odometer reads 185,000 miles
Symptoms:
- Rough Idle, Hesitation, Engine Shakes
- Bad gas mileage
Any thoughts?
Mar 8, 2017 at 9:54 PM
SATURNTECH9
  • 30,869 POSTS
The first thing I would be looking for is holes in the air I take tubes and vacuum leak somewhere.
Mar 8, 2017 at 11:06 PM
