2005 Hyundai Tuscon
72,000 MILES • 6 CYL • FWD • AUTOMATIC
SABITINO
shakes between 60-70 mph subsides going around corners on freeway air pressure good tires are normal ware
Jun 19, 2010 at 11:21 AM
MERLIN2021
  • 17,250 POSTS
If it happens only at high speed and no brakes applied, check tire balance, if OK, check for bent rims, or shifted belt on tires, Jack the front up, start car, put in drive, watch front wheels, bent rims and shifted belts on tires are easy to spot this way, tires will appear uneven(wobble).If they are OK, they will appear straight(no wobble).
Jun 19, 2010 at 11:41 AM
