2006 Hyundai Tiburon engine will not run
AMCENTARFFER
Engine Mechanical problem
2006 Hyundai Tiburon 6 cyl Front Wheel Drive Manual
my car will not start and run. it cranks over but will not fire. right before it stopped running it started to blow oil pretty steddily out of the cold air intake. the car does have some mods to it like a next generation motosports supercharger, headers and full custom exhaust. can you help me with some possible causes with why it won't run and why it blows oil?
Nov 17, 2008 at 6:21 AM
RACEFAN966
  • 5,029 POSTS
Well blowing out oil is never good usually means the engine went and will need to rebuilt or replaced. Now have you checked the oil to see weather or not it is low? Let me know how the oil level looks because a supercharger can spill out oil to when they go bad. So get back to me you probably should do a compression test too. Thanks and get back to me with what you find.
Nov 19, 2008 at 1:11 PM
