2005 Hyundai Tiburon control arm
2005 HYUNDAI TIBURON
49,250 MILES • 6 CYL • 2WD • AUTOMATIC
USMCCLARK
I was curious how much a control arm would cost for me to order a control arm i was looking on line for them and i found a few that were around 80 to 100 dollars and how difficult they are to put on. Note im on a military base with limited access to tools and space to work. would i need to compress the rear springs to do so. The syptoms are my rear passanger tire is cocked out im not 100% sure about wat it is.my friends told me control arm and i had no clue wat to think. just need some input on price and difficulty level.
Jan 31, 2009 at 8:23 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Before replacing the control arm, make sure it's bent. If it isn't, it should be ok. As far as replacement, it's a pain. If you need to compress the coil, you need a special tool to do it. Also, I believe the rear of your car is alignable. Have you had that checked?
Aug 6, 2009 at 9:45 PM
