2004 Hyundai Tiburon Shifting
2004 HYUNDAI TIBURON
56,000 MILES • 6 CYL • FWD • MANUAL
AIRFORCESTUNNER
When I shift it feels like it catches. In 3rd gear it is the most prodominate. I wanted to know if I need to change out my trasaxel fluid. If that would even help. I oiled all the ball joints on the shifter itself. Or is just that my clutch is going?
Mar 15, 2010 at 12:06 PM
  • 110,240 POSTS
You could check the fluid to make sure it isn't dirty or contaminated. Chancing it may help a little. Does it ever grind when you shift? Also, with the engine off, does it shift smoothly through the gears?
May 24, 2010 at 6:13 AM
RUNSTEVE
My son has the same problem with his 2004 Tiburon GT. When it warms up he has trouble getting it into 3rd gear.
May 23, 2013 at 9:38 PM
