2004 Hyundai Tiburon Keyless Remote dead battery
2004 HYUNDAI TIBURON
45,000 MILES • 4 CYL • FWD • AUTOMATIC
ROM285
The battery in my keyless remote died, and I made the mistake of opening the driver's side door with the key. Now, the alarm goes off any time I open the door and the car won't start. I talked with Hyndai and was told to disconnect the car battery with the key in the ignition on the "on" position. I did that. The car still won't start and the alarm still blares. What can I do?
Jun 21, 2008 at 9:31 AM
KHLOW2008
  • 41,814 POSTS
Hi rom285,
Replace the battery in the remote and use it to disarm the alarm.
There ought to be a manual alarm disarm switch which you press with the ignition on to disarm.
If without manual disarm switch, try turning ignition on and off repeatedly (should be 5 to 10 times) and see if the alarm is disarmed.
Jun 21, 2008 at 8:00 PM
