2004 Hyundai Tiburon Just Replaced Clutch, Car now cranks B
62,000 MILES • 6 CYL • FWD • MANUAL
SWEETI
Heres the Thing. The car has been sitting for about 2 months, until we could afford the clutch kit. We took the old one out and replaced it with the new. The original dual mass flywheel was fine, so we kept that in. Put everything back together. Got ready for a test drive, and it wont start. Cranks over, has plenty of juice to start. But just wont. Will however try to start, if you spray started fluid into the air intake. The clutch pedal pressure is fine, all connectors and harnesses were reconnected and in the proper places. depressing the safety switch, doesnt help. So my next step is a fuel filter, due to how long the car was sitting. Any suggestions?
Jun 22, 2009 at 7:01 AM
  • 110,248 POSTS
If it is trying to start with the starting fluid, make sure you are getting spark to all plugs. Also, I recommend checking fuel pump pressure. Here is a how to for both:
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Aug 6, 2009 at 2:20 PM
