2003 Hyundai Tiburon wont shift into 6th gear
HILDEBRANT01
Transmission problem
2003 Hyundai Tiburon 6 cyl Front Wheel Drive Manual
i had a new clutch put into my tiburon a couple of months ago and it has been shifting good, but recently it was hard to get into 6th gear. now it will not go into 6th gear at all. all the other gears are shifting beautifully. what is the problem and is this something that i should take it back to the mechanic to fix? also is this something they should take care of do to something they should have checked and tightened etc.?
Oct 11, 2010 at 1:22 AM
JORGELUISRODRIGUEZ
i have the same issue with my 2004 tiburon and nobody knows what the issue is, if you are able to find out please email me at jorgerodriguez724@gmail.com thank you !!!
Sep 5, 2012 at 2:07 PM
