2003 Hyundai Tiburon Rotors
2003 HYUNDAI TIBURON
FRANKY1
Brakes problem
2003 Hyundai Tiburon 6 cyl Manual
I am having trouble removing my rear rotors, I have removed the caliper and the screw that holds the rotor in but the rotor will not move at all. I can not see anything else that would be holding the rotor on.
Oct 8, 2008 at 2:18 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:7db15b6763="Franky1"]Brakes problem
I am having trouble removing my rear rotors, I have removed the caliper and the screw that holds the rotor in but the rotor will not move at all. I can not see anything else that would be holding the rotor on.[/quote:7db15b6763]
The screw you are talking about was it in the face of the rotor? If so there are usually 2 of them....
If not you may just have to beat on it some to break the rust from around the center. spray it with some lube.
Oct 8, 2008 at 2:22 PM
