HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Hyundai
Tiburon
Brakes
Pedal
2001 Hyundai Tiburon
JOEMIKE
MEMBER
2001 HYUNDAI TIBURON
Electrical problem
2001 Hyundai Tiburon 4 cyl Front Wheel Drive Manual
my brake lights wont shut off I tried lifting brake pedal no change I finally pulled the fuse what other
Saturday, July 5th, 2008 AT 1:50 PM
KHLOW2008
MECHANIC
Hi joemike,
Push the switch pin and if light still stays on, replace switch.
If light goes out replace rubber stopper on pedal at switch, you wouls see a hole, the stopper is worn.
Saturday, July 5th, 2008 AT 10:48 PM
Please
login
or
register
to post a reply.
Related Brake Pedal Content
2001 Hyundai Tiburon Told I Need Brakes
Brakes Problem 2001 Hyundai Tiburon 4 Cyl 90,000 Miles I Had To Relpace A Tire Recently And When That Was Done, I Was Told I Would...
Asked by
hcbrainard
2001
HYUNDAI TIBURON
2001 Hyundai Tiburon Rear Brakes
If I Understand Correctly, When Replacing The Rear Brakes On My '01 Tiburon, I Would Remove The Caliper From My Rotors And Then Push The...
Asked by
tj_1611
1 ANSWER
2001
HYUNDAI TIBURON
1999 Hyundai Tiburon Rotor Won't Come Free
A Very Cold Yesterday My Cousin Agreed To Put New Front Rotors And Brakes On My Car Like He Has Done To Many Cars Before. Took All Apart And...
Asked by
Kevin Rutherford
1999
HYUNDAI TIBURON
1997 Hyundai Tiburon Brake Pads
How Much To Replace Brake Pads? How Much To Replace Brake Pads And Rotors?
Asked by
RapmanJeff
1 ANSWER
1997
HYUNDAI TIBURON
2004 Hyundai Tiburon Emergency Brakes Release
My Emergency Break Handle Is Loose And It Feels Like There Is Not Resistnace On It. The Cable Snaped And I Had It Replaced In A Shop, But...
Asked by
mbordogna
1 ANSWER
2004
HYUNDAI TIBURON
VIEW MORE
Brake System Warning Light
ABS Module Replacement Video
Bleed and Flush Your Brake System Correctly
