2003 Hyundai Tiburon Replacing rear brake pads
2003 HYUNDAI TIBURON
61,000 MILES • 6 CYL • 2WD • AUTOMATIC
PAPPY2460
In attempting to replace the rear pads is it necessary to remove the cable for the emergency brake? Opening the bleeder valve would not allow the piston to be depressed to remove the caliper.
Jul 14, 2008 at 8:12 AM
BLACKOP555
  • 10,386 POSTS
the cable should be removed, for futher information i sugest consulting a repair manual.
rear brakes that have disks instead of drum brakes require a special tool to compress the cylinder. openeing the bleeder will not realease the piston
Jul 14, 2008 at 3:46 PM
