2003 Hyundai Tiburon Harmonic Balancer
95,000 MILES • 6 CYL • FWD • MANUAL
TANYAT
In changing the harmonic balancer, is it a single bolt holding it on or is it pressed on? Can you suggest anything on how to change the harmonic balancer?
Aug 19, 2009 at 9:09 AM
  • 31,937 POSTS
HI t ere,
The Harmonic balancer is normally just a hand fit when you remove the bolt, they can often bind up and a harmonic balancer puller is required to get it moving, these are available form most parts out lets,
mark (mhpautos)
Aug 19, 2009 at 7:25 PM
